Yep!!! Another wheel and tire question
Hey Ford owners! New guy here! Been searching this forum for over a year now and finally decided on some new wheels and tires. I have a 2004 4x4, XL model. I just ordered some Nitto Grapplers( 295/70/17) should be here in the next couple of days. But the wheels is what I'm having a hard time with. I have 2 wheels picked out........Eagle alloy 137 17x8 which has a BS of 4.95(offset +14) or a set of Ultra's 17x8 (5.5 BS). I want the tires to stick out a little past the finder wells. I'm thinking the Ultra's would stay tucked in with this tire size??? Anyways, just thought some of you wheel and tire buffs could help me out!!
So if I went with the Ultra's there would be a little tread sticking out? I don't mind a tire sticking out, as long as the tire is a "wide tire". I currently have 17X9 eagle 187's , with Firestone 265/70/17 which,to me, don't look right. I bought the truck used.
The Eagle 187's are 9 inches wide with 5 inches of backspacing, so they stick out 2 inches farther than the oem wheels. So both wheels you are considering will tuck in farther than the Eagle 187's.
Thanks Wandell!!!! I knew I could count on you!! I'll probably go with the eagle 137's, now i need to decide if i want all black or go with the straight polished!! Thanks again!!!
Looks good PawPaw!!! The Daystar leveling Kit you have, does it install the same as a AS does?
The new style daystar kit's are made like the autospring ones but are plastic. easier to install than the older kit's.
