part time pulsing brakes?
Old Apr 30, 2008 | 01:05 AM
basadochi04's Avatar
I have a little annoyance that I just cant stand any longer. Some times when I stop at say a red light from a high speed (50mph) it seems like the brakes will kinda pulsate, but if I let off the brake and get back on them it seems to stop sometimes. what do think it is? no ABS light is on, I checked the wheels last time I drove and none of them seemed hotter so sticky caliper is ruled out, if the rotors are warped wouldnt it do it all the time?
Old Apr 30, 2008 | 05:33 AM
keith97xlt's Avatar
gonna have to pull the wheels off and investigate. could be time for new pads, tires might need a balancing.check all your suspension parts also.
Old May 1, 2008 | 06:14 PM
ok, well I know it isnt the balance cause I just balanced them at my buddies shop and no weights are missing. I know I dont need new pads cause there is still half of the stockers their. None of yall have this problem?
Old May 2, 2008 | 05:21 AM
keith97xlt's Avatar
i dont know what to tell ya. i have a 250 superduty and mine pulsate a little to at 50- 60 mph. is it real bad.??.. steering wheel shaking out of your hand bad??? you said your buddy has a shop does he have a rotor machine?? give them a turn maybye that migh help.
Old May 2, 2008 | 06:09 AM
gpaje's Avatar
When you say pulsing brakes, do you mean felt thru the pedal or steering wheel?
If it's the steering wheel, its probably your rotors temporarily warping due to heat. If they were turned, they maybe borderline too thin, and warp when they get hot. That's why you may only notice it sometimes.
Old May 2, 2008 | 09:25 AM
dirtyd88's Avatar
i have been told by midas that my rotors are warped, but they dont pulsate everytime i stop. once you step on them, after not using them for alittle bit, the rotors are cold so you feel them pulsate, but once you apply the heat that the pads create, the rotors tend to expand alittle bit making the pulsating not near as bad. i wouldnt woory about changing them, making just have someone look at them, and do a turn job if you want to.
Old May 7, 2008 | 11:47 PM
mauliemal's Avatar
i have the same problem. i have a 07 stx, just got it in january..it has 25k miles on it. everything is stock on it..now i dont feel it in the steering wheel or pedal, but you can feel the truck as is it does it. its almost as if the rotors are wop, i donk know man
