Balancing Problem
Balancing Problem
Just put on a new set of black Ultra wheels and have been to 4 different shops to try and get them balanced. Problem is they cant put any weights on the front of the wheel. They can put stick ons but they ruin the looks of the wheels. The stockers ran smooth as silk. Used the same tires. Anyone have any experience with this??Or a solution?? The way it is now I'll either keep the wheels and the good looks or switch back and have a smoother ride.
What exactly do you mean by "they can't put weights on the front of the wheel"?
Here's a picture where they stuck some weight on my wheel, you really can't see them unless you've bent down and are looking into the wheels.
If they really bother you, paint the weights black!
There is no other solution I know of. If the wheel is unbalanced, you need to either add or take away weight from somewhere...
- NCSU
- NCSU
The weights were not thin enough to clear the caliper. The only other area to put them would be in sight. 1 guy did suggest the paint em deal. That maybe my only way out if I'm gonna keep the wheels. I really like the look of the Ultra wheels. I stayed with the stock size 17's to keep my mpg's and its came back to bite me.
What kind of MPGs are you getting currently?
- NCSU
Tell me more!! If this goes inside the tire will it damage the TPMS sensors??
I don't know. I know a few members at FTW with Super Duty trucks on huge tires use some of these systems. I don't know a lot about them. I was hoping one of our site sponsors would chim in on this.
May have found the solution to this balancing problem per the dealers suggestion. Anyone hear of Dyna beads?? Or use them?? http://www.innovativebalancing.com/
I wanna keep my wheels but the vibration is drivin me nutty.
The beads are not supposed to clump with moisture buildup like the powder. I went ahead and ordered today so I'm gonna find out pretty soon if they work. Have had a few give em a good rep. Bike shop near here uses them all the time and say they work great for them.
