35s with 20s
Old Apr 26, 2008 | 12:51 AM
ColonelBlue's Avatar
35s with 20s
this is prob a dumb question but could 35 tires with 20s fit under a 4 in lift?
Old Apr 26, 2008 | 06:07 AM
Big50's Avatar
There should be no problem what so ever. The diameter of the tire is the only thing you have to worry about, not the rim.
Old Apr 26, 2008 | 09:45 AM
ATOM's Avatar
if you are referring to the rancho 4" lift it yeilds 5.5 inches of lift in the front, so you can fit 35's fine.
Old Apr 26, 2008 | 10:53 AM
wandell's Avatar
Big 50 is right. You can fit a 35x12.50 using 17, 18, 20, 22 or 24 inch wheels. I'd suggest a 20x9 inch wheel with 5 to 6 inches of backspacing.
