Need Opinions on Backspacing and Offset
I'm going to order rims right shortly here. I am going with 22" again, but I am not really sure what I should go with for backspacing and offset. I don't mind if they stick out a little bit more then stock, but I don't want to be going around looking like an R/C Car or anything. What do you guys figure is the ideal spacings to run.
My tires will be 305/45R22
Wheels I am guessing will be 9.5" wide
And I will be running a 2"/3" Drop.
Thanks for any help you can offer.
Try this link to a really cool tire calculator/comparison tool.You put your stock wheel and tire specs. in the first column, and the specs. of the set-up you want to run and it tells you if it will work.
