Will these fit
Will these fit
I have a 05 fx4 with a 2.5 level kit. I have seen in other threads that 35's will fit. I wanted to see if you guys think I can squeeze these on. Also the rims have a different bolt pattern. Have any of you ever used the bolt adapters to change your bolt pattern? Is this safe?
"four 20 inch moto metal rims with 35" Toyo Open Country Mud Tires with 70% of the tread still on them. Tires are in great shape and still have 2 or 3 years of life left in them. Only used for three months and were $300 per tire. Rims are in very good condition. One rim has a tiny scuff from a curb, but is barely noticeable/ hard to see. Were previously on a dodge ram 1500 and they fit great without a lift or anything. The lug pattern is 5x5.5. Will fit 02-08 dodge rams or 02,05-08 dodge durango.
The people running 35's with a leveling kit are using the oem wheels or one's almost identical to their specs. The Moto Metal wheels are not even close. Using a bolt pattern adaptor will push the wheels out even farther and cause more fitment issues.
