tire pressure
tire pressure
Ok, i got my bfgs a couple months ago & im not sure exactly what pressure to run them at. On my paper work from NTB it says to put 32psi front & 35psi rear.
but for stock 265s on the gas cover it says to run 36psi around.
so what would be a good pressure to run them at?
Sounds like NTB is trying to kill you. Those are Load Range D tires with a max of 65. Run them at 45. The 36 on the door is for the OE tires, which were probably a LR C tire. The 32 is even too low for P series tires on an F150.
yeah i have a set of 315/75/16 pro comp xtreme A/T's and the max pressure rating on the sidewall says 50 psi and thats what i have been running them at but the ride seems a bit rough, do you think i should take a little out?? but i am always willing to sacrafice ride quality for getting the most life out of my tires.
For maximum MPG, I always use the MAX PSI on the tire. Of course, with MAX PSI, you will not have the smoothest ride. I don't pay attention to the sticker inside of the door frame. The sticker does not know what kind of tires I'm using.
thanks for everything guys, i was runnin 40 in em but someone told me that was too much but i liked the way they looked & rode with 40 so im gunna put em back to 40
thanks again
thanks again
