Gauge Accuracy and LT Pressure Question
Old Apr 5, 2008 | 07:19 PM
junior's Avatar
I have three different tire gauges, one digital and two different analog dial type. They are all within 0.5 psi of each other, can I assume that these gauges are all accurate? I mean, it would be really really good(or bad) luck to have three different brand gauges be exactly incorrect together right? These gauges, however, differ from the the tire dealers gauges, how can I tell which is the correct one to trust?
Secondly, I just put LT265/70-17 tires on my 2004 4x4 Supercrew for the upcoming summer trailering season, the placard on the B Pillar says 35psi front and back, but that was for the stock P-metric P255/70-17 only I believe. The dealer put them all at 40psi and they are listed max at 50psi. Is there a good rule of thumb on where these tires should be, I don't think that they had any specific information on their choice of 40psi installed.
On a side note, I am really pleased with the LT tire in the way it smooths out the ride, it did not make for a rougher ride, which I thought it might, the tires just seem to absorb the road instead of bounce off it now.
Old Apr 5, 2008 | 07:31 PM
Yes, when you change tires you can disregard what's on the door jamb. If your new tires have a max of 50psi, 40-42 psi would be a good number to run if the ride is not too harsh. I have load range "D" tires 50psi max. and I have been running them at 42-44 psi. and they have been wearing great. Also a little more air will improve your gas mileage. Every little bit help's with the price of gas!
Old Apr 5, 2008 | 08:45 PM
junior's Avatar
Thanks for the info on the LTs, should I keep the front and back pressures the same and/or do the wet tire/dry pavement contact patch trick or just hang around 40-42psi and put this all behind me?
Anyone want to chime in on the tire gauge dilemma I have?
Old Apr 6, 2008 | 07:45 AM
kingfish51's Avatar
If those are a load range C tire with a max of 50, run them at 40, which is what Ford recommends on the door sticker for that LR tire. A D load range might be slightly higher, but not much.
