Wheel Size For 06 F150
Old Apr 5, 2008 | 12:43 AM
DOTY's Avatar
i'm planning on running a 2 1/2" leveling kit with 35x12.5r20 geolanders mt's
how wide, how much back spacing and offset should i get ?
thanks Doty
now wanting a 325/50r22 look below to new post
Old Apr 5, 2008 | 09:19 AM
wandell's Avatar
Most people running 35's are using the oem wheels. If you are gonna use aftermarket wheels you are gonna need one almost identical to the oem wheels. You could use a 20x8 inch wheel with 5.5 inches of backspacing.
Old Apr 5, 2008 | 07:24 PM
DOTY's Avatar
thx for the info
i think i'm going after market
Old Apr 5, 2008 | 11:00 PM
wandell's Avatar
Like I said, just be careful with the wheel's specs.
Old Apr 15, 2008 | 11:52 PM
DOTY's Avatar
changed my mind, i've order a auto spring 2 1/2" leveling kit for my o6 screw and i'm wanting to run a 22" wheel
i like the look of the 325/50r22 with a all terrain pattern
how much offset and bs will i need on the new wheels to stop rubbing?
Old Apr 16, 2008 | 09:41 AM
wandell's Avatar
Actually, you are gonna need more lift to run a tire that large.
Old Apr 16, 2008 | 07:55 PM
DOTY's Avatar
what size tire would work for a 22 and a 2 1/2" leveling kit?
i like the look of a wider tire also
Old Apr 16, 2008 | 08:20 PM
wandell's Avatar
305/45-22's (33x12.50-22).
Old Apr 16, 2008 | 10:25 PM
DOTY's Avatar
i know a 305/40 22 will fit stock so i would assume a bigger tire would fit with the leveling kit
i'm going off of what blackout-fx4 said in a different post
Originally Posted by BLACKOUT-FX4
i have a 2.5 autospring leveling kit. my rims are 22" and tires are 325/50/22(35")
i know a 325 is pretty wide so maybe even a 305 or 315 50 r 22?
if anyone has pics of this set up please post
