Disk to Drum Conversion HELP!
Old Apr 1, 2008 | 02:55 PM
braupe's Avatar
Hello all,
As the title says I am cursed with rear drum brakes. I was wondering what parts do I need to convert to rear disk? I am trying to do this on my 99 f150 2wd 4.6 auto. I think the axle code is 19 if that helps. I also have 3.55 gears and an open diff.
Thanks for any and all info.
Old Apr 1, 2008 | 03:06 PM
braupe's Avatar
Would these work?
http://cgi.ebay.com/ebaymotors/ws/eB...TQ:MOTORS:1123
Old Apr 1, 2008 | 05:45 PM
NoLongerJeepin's Avatar
when you do this type of conversion with jeeps you swap the entire axle. i dont know if your axle works with disk brakes. just my .02
Old Apr 1, 2008 | 07:36 PM
F151's Avatar
When i did the 'Stang I used parts off a Lincoln Continental...... Caliper brackets, rotors, calipers, proportioning valve........ If you could get these parts off a truck with discs up to an '04 Heritage.
Old Apr 1, 2008 | 08:21 PM
ONELOWF's Avatar
I think you jeep guys like the 8.8 swap?
An Expy disc rear end is supposed to bolt into 97-98, maybe 99?
Old Apr 1, 2008 | 09:55 PM
braupe's Avatar
I guess I will just shop around for a rear end with disks. They did make f150's with rear disk in 99 correct?
Old Apr 1, 2008 | 11:25 PM
wookie13's Avatar
i thought all 99s had rear discs my uncles old 98 had rear drums
Old Apr 2, 2008 | 12:59 AM
97XL's Avatar
You can check this site but it looks kinda pricey to me.
http://www.tsmmfg.com/2530M.htm
Old Apr 2, 2008 | 11:44 AM
braupe's Avatar
Thanks for the info, it does seen a little pricy, Im going to shop around for a expy rear end or f150 rear with disc.
