Need help before purchase
Old Mar 26, 2008 | 06:42 PM
PaintballKid's Avatar
Exclamation Need help before purchase
I have an 06 F-150 2wd with a leveling kit. I am going to purchase 285/70/17 BF Goodrich A/T. I am also ordering rims Pro Comp 17x8 6 on 135 with 0mm offset and 4.5 inch backspacing.
Will this fit on the rim? and if so how much will the tire stick outside my wheel well.
I know the tire will fit just fine, I'm just confused on the whole b/s thing.
Please and thank you.
Old Mar 26, 2008 | 10:19 PM
wandell's Avatar
The tire will fit the wheel perfectly. That wheel will stick out 1.5 inches farther than the oem 17 and 18 inch wheels since it is 1/2 inch wider and has an inch less backspacing than the stockers (7.5 inches wide with 5.5 inches of bs).
