Toyo MT's
Hey everyone I am definitly going to get the Toyo Open country MT. I just want to make sure that i am not missing anything. I have a 2004 scab with a 2 inch Autospring leveling kit installed. I have stock rims. I want to get the 315 70 R 17 tires. These roughly come out to a siewall eight of 8.68 a section width of 12.4 and the overall diameter is 34.36. All i need to know is will these fit without any rubbing? O and also if i were to get the 35X12.5 is that basically the same-thing or not. If you guys could help me i would be grateful. Thanks Guys!!!
I think you will have some rubbing with the 35" Toyo MT's. I would also check out the 305x70x17 Maxxis Buckshot's or Bighorn's. They will work on the stock wheels, cost less and give a little more clearance. Just an idea!
I have a 2.5in leveling kit with 35 12.5 18 Toyo Mt's and I do rub my control arms at full wheel lock. I've gotten used to it though, and so far no damage. I would say you could DEFINATELY go 33's without rubbing, but not sure of anything larger than that.
Ok i do not think i will go any bigger than 33. Does Toyo make a 33 for 17 X 7.5 rim? And if i do get these tires should i get the car re-geared? Thanks for all of your help i know i am beating a dead horse...
Go with these
If you want to go 33". Go with the Toyo MT 295/70 R17, this comes out to be 33/11.50 R17. These are absolutely one of the best mud tires on the market. I have never heard of one complaint out of these tires. They are tough, good looking, and have more bite than you'll probably ever need. Good Luck!
295/70/17 is actually basically a 34x12. (285/70/17 is a 33x11.50). The 295 is a great size! Do a search in the galleries just type in 295/70/17 or 295/70R17 and it will come back with any gallery of someone who has listed that tire size.
Is it normal for the tires to make turning a little stiff?
I put a set of Toyo' on my truck and have noticed that turning the steering wheel is more stiff than it was with the stock tires. I was wondering if I had some other problem causing the stiffness, but thought i would inquire here before I start looking into it.
Actually, that is just a guess but is sounds good, no?
