Wandell and other wheel pros please help!
Old Mar 11, 2008 | 12:50 PM
Rao11010's Avatar
Yet another bs and off set thread that have yet to understand. I have a 04 F-150 with a procomp stage 2 with the coils cranked. I looking to go with a 22" wheel on 37/13.5 Toyo M/T...A member on the site has xd badlands but when I go to search for their 22 by 11 the only size close is a 6x139.7? will it match?
If I do seem to ride the correct lug patteren the badlands have a back spaceing of 4.27 and off set of -44? question is will it be too wide? will the sidewall of the Toyo M/T rub the spindle?
any other 22" wheels you might suggest?
Thanks a ton Ryan
Old Mar 11, 2008 | 02:38 PM
BLACKOUT FX4's Avatar
those m/t have a very aggressive sidewall but with that -44 offset that should push the wheel/tires out far enough not to rub anything on the inside. is the pro comp a 6" lift? i think your issue may be rubbing the fenders at the 9 o'clock and 3 o'clock spots when turning. i have xd monster 22x9.5 + 18 offset with 35" terra grapplers and running a 2.5 leveling kit. i have no rubbing on the inside at all. and thats a +18 offset, you are looking at a -44 which will stick out a coulple of inches more than mine . you shouldnt have any problems. i have pics in my gallery if interested
Old Mar 11, 2008 | 04:24 PM
wandell's Avatar
First of all you have to have a 6x135mm bolt pattern. Also, a 11 inch wide wheel with 4.27 inches of backspacing is gonna stick out about 4 3/4 inches farther than the oem wheels.
Old Mar 24, 2008 | 12:27 PM
Rao11010's Avatar
which one
alright one more question. which bs and off set would go better for my application? 5.25 BS with 0 off set or 4.75 BS with -25 off set. please let me know which wheel would work better with less rubbing.
Old Mar 24, 2008 | 12:36 PM
Hash278's Avatar
Since you want to go with 37's, if you dont want to rub I think the 0 offset would be better. Wandell can confirm for sure.
Old Mar 24, 2008 | 12:42 PM
wandell's Avatar
I agree.
Old Mar 24, 2008 | 12:45 PM
Rao11010's Avatar
how much rub
how much do you think the -25 off set wheel would rub. this is a 22 by 10.5 wheel by the way
Old Apr 14, 2008 | 01:33 PM
Rao11010's Avatar
back to the question one more time how much do you think the 22 by 10.5 with 4.75 bs and -25 off set rub. last question I promise
Old Apr 14, 2008 | 08:17 PM
wandell's Avatar
I'm not sure. I think you will have some rubbing, but I'm guessing it won't be bad.
Old Apr 14, 2008 | 09:00 PM
Rao11010's Avatar
so in all honesty should I spend the money on them or will it not even be worth the try. thanks ryan
Old Apr 14, 2008 | 09:01 PM
wandell's Avatar
I'd do a little more reseach before buying them.
Old Apr 14, 2008 | 10:08 PM
Rao11010's Avatar
alright thanks for the help but one more time before considering how much should the wheel/tire stick out of the truck
Old Apr 15, 2008 | 09:16 AM
wandell's Avatar
Is the wheel 11 inches wide or 10.5?
Old Apr 15, 2008 | 09:54 AM
Rao11010's Avatar
the wheel is 22 by 10.5
Old Apr 15, 2008 | 04:12 PM
wandell's Avatar
A 10.5 inch wheel with 4.75 inches of bs will stick out about 4 1/4 inches farther than the oem 17 and 18 inch wheels.
If you could fine a 9 or 10 inch wide wheel with 5 inches of bs you would be better off. A 9 with 5 inches of bs would only stick out 2 inches farther than stock and a 10 would only stick out 3 inches farther than the oem wheels.
