Backspacing Problem??
Old Feb 27, 2008 | 12:49 AM
FSEX4's Avatar
Hello guys (and gals), I'm new to the site so bare with me. I have a 07 FX4 and I'm putting a Fabtech 6" lift with bilstein shocks. The rims that i want are MKW M19 series, 20x9 with 5.39" backspacing. I want to run a 35X13.5 cooper STT tire. Do you think I will have a problem with rubbing???
here is the wheel
Old Feb 27, 2008 | 10:17 AM
wandell's Avatar
You should be fine unless Fabtech has backspacing requirements that the wheel doesn' meet.
Old Feb 27, 2008 | 12:28 PM
duece212's Avatar
Fabtech recommends a 9" rim with 5" of BS. I'm kind of curious as well if a person can run a little more BS. 4x4LariatMan here on the site is running 9" rim with 5.5" of BS on his fabtech lift.
I just ordered some rims with 5.5" of BS, but they won't be going on till the middle of next month, hopefully they work.
Old Feb 27, 2008 | 01:34 PM
051fdrof's Avatar
I would contact Fabtech unless someone chimes in with the same combo you want to run. I have a set of STTs and the side-biters eat up a little clearance all by themselves. I think you might be pushing your luck.
Old Feb 27, 2008 | 03:35 PM
FSEX4's Avatar
Well I just got off the phone with the fabtech guy and he said the recommend 5" backspacing but he said no more than 5.25".....5.39 doesnt seem like that big of a difference, however it might make all the difference.
Old Feb 27, 2008 | 03:38 PM
051fdrof's Avatar
Did you tell him that you planned on running muds with big side-biters?
Old Feb 27, 2008 | 04:52 PM
FSEX4's Avatar
No i sure didn't hang on....i'll call back
