tires and gas mileage
i have a 97 f150 4.6L. 98,000 miles k&n intake jet performance chip and a flowmaster with 3.55 posi gears and 235/70/16 tires and getting about 12-13 ish mpg. i can make a little over 300 miles per tank. my buddy has a stock 5.4L. with 265/70/17 tires and a 3.55 posi im not sure exlacty but he can get a lot more miles per tank then i can. i was wondeing if i put 265/75/16 tires it would help the gas mileage?
I have a 1997 f-150 with the 4.2 and i just recently had 265/75/16 and i was getting about 13-14mpg with them I believe i have 3:55 also not exactly sure but i switched to 285/70/17 now im getting about 11-12..I have my old rims and tires forsale for 400$ for everything if you are interested i can send some pictures
i looked up your chip and it says you can use 87 octane but it was designed for 89-93. this may be attributing to the crappy milage. since the chip advances the timing i would go ahead and start using atleast midgrade. have you had any knocking with that chip? if so this should fix it
thanks man. do you think i could just buy some octane booster and not actually spend $3.50 a gallon or whatever it is
Driving habits are the most significant impact on fuel usage. Comparing yourself to any friend or anyone on the internet is a waste. I've never gotten more than 14.5mpg in 50 miles in my current F-150.
Spend $5/tank on octane booster or $2 for mid-grade fuel? That doesn't make financial sense, even it did work (which it doesn't).
Remove the chip and Blowmaster to increase fuel economy maybe by 15% if you are unwilling to change driving habits as most people are.
