backspacing and offset help!
I am going to get ready and order my new wheels and tires am im going ot go with toyo's 35x12.50x20 and procomps 6001 20 inch wheels. I have aa 2 inch leveling kit and a 3" body lift. I am running 35x12.50x17's now. I want my wheels to be a deeper dish than my current. Would a 4.5 backspace and -12mm offset be way to much and cause rubbing issues? I want my tires to stick out more than now also. Thanks for the help!
they are a 20x9.....how much farther will they stick out from my setup now and how much deeper will the wheel be? I currently have a 17x9 with 5.5 backspace and 12 offset. Thanks
Jessie, I am not trying to hijack your thread but how hard was that body lift to install? Did you do it or pay someone? I am about to do the same so any help you could give would be greatly appreciated. Thanks
I am thinking of that same set up almost but my tires are a little wider than12.50 the rims that i was thinking of getting are the same specs
do you have any regrets about doing a body lift
wandell do you think the additional width will matter my tires are 325/60/20
sorry for the high jack
