power slot rotor ?
power slot rotor ?
i am planning on relpacing the rotors and pads on my 2006 4wd supercrew.
where can i find the best prices?
What would be the stock#
What pads would be best suited? Carquest, hawks etc...
check out www.rotorpros.com i got my front rotors from them for $250 drilled slotted and powdercoated
My Power Slot Cryo rotors have been ordered and are on the way!
I also went and bought some Carquest blue pads for them. The Power Slots are some of the better rotors out there. I was going to go with Rotorpros, but most of those off brands don't give you more than a 30 day warranty if that! Power Slots are a proven rotor. The Cryo rotors are frozen to 300 degrees below 0 and than brought back to a normal temp through a special process. This hardens the rotors and gives them great strength and prevents warping. I got mine from www.ajusa.com
Here's their link. Everyone should read up on them!
http://www.powerslot.com/pages/power_slot_cryo.html
I looked at them. At their price your haft way to Force 10. Since I rotate my tires I'll be inspecting the rotors often and if a problem ever presents itself I'll be the first to say so. Right here.
Thanks for the info.
My front rotors need to be replaced. i had them turned and placed the carquest pads. I ran my fingers across the rotors and they have grooves.
What gives, i have less than 8k miles on them.
Could i possibly not have broken them in properly or could the rotors have been turned to thin?
BTW - i found the power slots cryo's for less at summit
