will these fit?
Old Jan 27, 2008 | 03:46 PM
btag601's Avatar
will these fit?
i have a 2006 f150 supercab with a 2.5 leveling kit and 305/70/17 nitto terra grapplers and i want to order these rims but i'm not sure if they will fit, any help would be awesome:
Pro Comp series 107 17X8, bolt pattern 6x135 with a backspace of 4.5 inches.
Old Jan 27, 2008 | 09:10 PM
Those will stick out about 1 1/2 inches more than stock. I think they will clear the front but you may get some rubbing on the lower wheelwells when making hard crank's. I would go for it because they will look great, any rubbing will be real minor.
Old Jan 27, 2008 | 09:22 PM
wandell's Avatar
I agree.
Old Jan 27, 2008 | 10:12 PM
btag601's Avatar
appreciate the help guys
Old Feb 23, 2008 | 09:27 PM
JonnyT's Avatar
How about the same pro comp 107 witha 17X9 with Back Space = 4.75 in....Same 1.5 inch farther and minor rubbing if any?
I have the same set up leveled up front. Thanks for the help
Old Feb 23, 2008 | 09:32 PM
What size tires you runnin' on 'em?
Old Feb 23, 2008 | 09:33 PM
JonnyT's Avatar
Probably the same 305/70/17 nitto terra grapplers
Old Feb 23, 2008 | 09:42 PM
That setup will stick out 2 1/4 inches more than stock. The 305's may be close on the lower wheelwells when hard cranking and may rub a little doing any rough offroading. If they clear they will look great!
