Sizing Help!
Old Jan 25, 2008 | 06:25 PM
Flan's Avatar
Sizing Help!
I've got a 02 Ford F150 Supercrew 4x4 XLT and want to get BFG All Terrain T/K A/O Tires. I was planning on a getting 16x10 7089 Pro Comp rims to go along with them but now I see I cant get the bolt pattern for the 10" anywhere, only 8". So what is the biggest size tire that will go on that rim without a lift kit? Or do you know where I can get 10"?
Old Jan 25, 2008 | 08:45 PM
wandell's Avatar
You can fit a305/70-17 (33x12.50) using either wheel, but IMO 16x10's look much better. You will have to trim a little plastic off your front bumper's lower valance to fit 16x10's but it's unnoticable if you are careful. I have some pics in my gallary. Check out Eagle Alloys website, they make several 16x10's.
Old Jan 27, 2008 | 02:43 AM
Flan's Avatar
You do mean 16 right? Not 17? will these tires fit on my stock wheels? Pretty sure I have 16s on my truck
Old Jan 27, 2008 | 09:45 AM
wandell's Avatar
Yep, it was just a typo. You can fit 305/70-16's on the OEM 16x7 wheels but they are a little too wide. This can cause the center portion of the tread to wear slightly faster than normal, similar to running too much air pressure.
