Will these fit????
Old Jan 19, 2008 | 09:13 PM
GageCreasy's Avatar
Will these fit????
Nitto Mud Grappler 35/12.50/20.
I have an 05 FX4 with a 2.5 leveling kit. I have aftermarket rims that stick out about an inch further than stockers. Thanks.
Old Jan 19, 2008 | 10:59 PM
Acerocks's Avatar
Everything I have read on here in the last 2 weeks tells me no. Unless you are willing to do some trimming. Your problem is the aftermarket wheels sticking out. If you kept the tires on stock wheels then yes with some rubbing on your upper control arm at full lock. Good luck
Old Jan 19, 2008 | 11:19 PM
wandell's Avatar
Probably not. How wide are they and what is the backspacing?
Old Jan 19, 2008 | 11:53 PM
keith_bennett's Avatar
Im gonna say no, regardless of rims because Mud Grapplers have such an extremely aggressive sidewall, they will rub pretty bad at full lock.
