Help!
Old Jan 17, 2008 | 09:44 AM
superduty1999's Avatar
Exclamation Help!
Does anyone know where I can find 1/4" hub centric wheel spacers for my '05 F150 4x4?
Old Jan 17, 2008 | 01:17 PM
smitty'slariat's Avatar
try discount tire, or search the web.
Old Jan 17, 2008 | 05:39 PM
I've already tried that. The problem that I'm having is that the factory Ford wheels on my truck are hub centric. When I put my new tires on the truck I had to put a 1/4" spacer on the front to keep the tire from rubbing the upper control arm. The only problem is the spacer moves the rim away from the hub lip that the rim centers on. So now when I go to put my front tires on the truck I need someone to help me center the rim manually. It's a pain in the a**! There has to be a better way.
Old Jan 18, 2008 | 02:09 PM
High Profile's Avatar
go get some acorn lug nuts instead of the factory flat washer style... they will center on the studs instead of the hub.
