Is it wrong...
Old Jan 11, 2008 | 01:38 PM
gillster's Avatar
Is it wrong...
to run different namebrand tires on the front and back? Tire size is the same, 275-65-R18, just the front are BFG's and the back are GoodYear's.
Someone told me they might be different weight or width and it would put additional stress on the 4X4 system???
Old Jan 11, 2008 | 04:52 PM
CRF250rider1000's Avatar
As long as the diameter is the same I really don't see an issue, but I could be wrong
Old Jan 11, 2008 | 06:05 PM
keith_bennett's Avatar
I have seen it done alot, but sometimes tires measure differently. Like with 35's for example. Some are 34.6 and some are 34.8 and some are true 35's. I really dont know though.
Old Jan 11, 2008 | 10:07 PM
wandell's Avatar
You should be fine. Just don't mix radial and bias ply tires.
Old Jan 12, 2008 | 01:20 AM
Grubrunner's Avatar
Why would you want to do that...
Old Jan 12, 2008 | 10:05 AM
wandell's Avatar
You wouldn't, but it used to be a problem before almost every tire was a radial. Now, only a few truck tires (like Super Swampers) are bias ply.
Old Jan 12, 2008 | 01:44 PM
gillster's Avatar
Thats what I thought.
Thanks.
Old Jan 12, 2008 | 02:15 PM
OhioLariat's Avatar
Probably doesn't apply in your case, but you also don't want to mix speed/performance ratings, either. Different sidewall strengths/flexibilities can do odd things to handling. This can even be a factor from brand to brand.
Andy
