15" rims
Old Jan 9, 2008 | 01:56 AM
chris03f150's Avatar
15" rims
i have a 2003 150 fx4 with 17" rims stock will 15" rims fit or not clear the brakes?? i can get a smoke'n deal on tires and rims?? just wondering before i jack it up and find out???
Old Jan 9, 2008 | 02:04 AM
MmmBuckles's Avatar
nope.
Old Jan 9, 2008 | 02:22 AM
Fireman 708's Avatar
No, you might be able to fit 16's but I am not for sure about that. My 97' the brake assembly was 15 3/4" so 16" was the smallest! Don't worry about the cash and throw some 18's, 20's or 26's on it!!
Old Jan 9, 2008 | 09:20 AM
i didn't think so thanks for the help looks like i got to plan on the 18's!!!
Old Jan 9, 2008 | 09:57 AM
jk007's Avatar
16s is going to be the smallest you can fit on the 97-03s...
Old Jan 9, 2008 | 12:52 PM
wandell's Avatar
THat is why you won't be able to fine a 15 inch wheel in our 5x135mm bolt pattern.
Old Jan 9, 2008 | 04:30 PM
keith_bennett's Avatar
Jeeps have the same bolt pattern as fords bolt pattern. So you can find them.
Old Jan 9, 2008 | 04:32 PM
wandell's Avatar
I don't think the jeeps use a 5x135mm. I think they use the same bolt pattern as the Explorer. At least the Wrangler, Cherokee and Grand Cherokee did.
Old Jan 9, 2008 | 04:39 PM
That weird, because i found alot of wheels with 5x135 bolt pattern 15" when i thought they could fit.....
Old Jan 9, 2008 | 04:56 PM
Kieth i have the same truck as you with a 3"BL do you have to crank the torsion bars to fit 35's"? I was thinking of putting on 33's! any in put??
Old Jan 9, 2008 | 05:09 PM
EBROTEN's Avatar
Wandell is correct. Jeeps have a 5x4.5 lug pattern. Same as Rangers, older Explorers and 2wd Yota's.
Old Jan 9, 2008 | 06:15 PM
No, i didn't crank the torsion bars at all. Go with 35's, you will be happy. I did have to trim a little on the lower part of the valance, it took about 5 minutes.
