Will 33's fit?
are 33's a better choice than 35's with a leveling kit..
i hear gear changes are recommended... even some rubbing with 35's
i thought 33's would give it a nice stance... maybe throw on a leveling kit..
and stay problem free..
You don't need a levelin kit for a 97-03 4x4 because the front ride height is adjustable via the preload on the torsion bars. The leveling kits for these trucks are just re indexed torsion bar adjustment keys that allow you to do the same thing. Also, you can fit 35x12.50's on a stock 4x4 by using the oem wheels, but it's a very, very tight fit and they will rub the frame at full steering lock. I'd suggest running 33's and later adding a set of wider aftermarket wheels.
