Tire pressure on 150 20's
Old Dec 25, 2007 | 01:58 PM
king rancher4x4's Avatar
I've got a new 2008 King Ranch with the optional 20's. The door jamb says 35 lbs of pressure. I'm wondering if that was meant for the 17's that originally came on the vehicle. does anyone know the correct pressure for the 20's ?
Old Dec 25, 2007 | 02:04 PM
kingfish51's Avatar
The pressure on the door jamb is for your particular set up. The Pirellis are P-series tires, with I believe a max of 44 (Considered a extra load P-series).
Go with the 35.
Down the road, if you swap to tires with a different load range, then you will have to figure out what pressure to use for them.
Old Dec 25, 2007 | 02:05 PM
wandell's Avatar
You are right. Ford recommends 35 psi for the 20's. I try 40 psi.
Old Dec 25, 2007 | 03:27 PM
JMBdevotee's Avatar
I run mine at 40psi.
