Wheel/Tire ??
Old Dec 23, 2007 | 10:35 AM
VAUGHN22's Avatar
Question Wheel/Tire ??
I want to go with Procomp 6089 wheels 18x9
and BFG 305/65/18's.
If I order the wheels just using the year and model
truck, will I get the wheels with the stock back spacing? Which I'm guessing with the 9" rims will rub big time?
If so, what back spacing should I order on the wheels using 305/65 tires and not have rubbing OR stick out alot passed fender?
Thanks in advance..
Old Dec 23, 2007 | 05:10 PM
wandell's Avatar
I don't know the backspacing on that wheel, but you can find it on Pro COmp's website. I'm 99.9% sure it's less than the OEM backspacing of 5.5 inches. If you can find an 8 or 8.5 inch wide wheel with 5.5 inches of backspacing, you will be fine with that size. I know a lot of people run 325/60-18's on 9 inch wide wheels but that tire is a little shorter and a little wider than the BFG's. You can probably fit the BFG's using a 9 inch wide wheel with 5 or 5.5 inches of BS but that is just a guess.
Old Dec 23, 2007 | 06:01 PM
Stephen S's Avatar
It doesn't work that way. You get the backspacing that the manufacturer designs and builds for that wheel size and lug pattern. For your wheel, that's 4.75" (from Pro-Comp website specs).
