Little clips on brake pads
just installed the carquest blue semi-metallics on the front.... looking at them in the box noticed that 2 out of the 4 pads had a little clip towards the end...
started with drivers side... the inner pad had the little clip towards the bottom...
get to passenger side and little clip is on the outer pad towards the top...
no mention of this clip in the haynes manual, no mention of the clip in the spartan instructions included with pads, or anywhere else I had immediate access to... so for uniformity I installed both little clips on the inside pad towards bottom
so - where do they really go and what's their purpose
thnx
thnx
Originally Posted by torkum
Think you are talking about the wear indicater. When the pads wear down the tab rubs the rotor to let you know when the brakes need attention.
yeah - think you're right! since there's only 2 of them out of 4 pads, where do they go
Originally Posted by F151
Anti-rattle......
Take a look at "ears" of the pads with the wear indicators. The ears are the extensions on the ends of the pads that ride along the stainless steel slippers on the caliper brackets. One end of the pad has an ear the looks like this: [
The other ear looks like more like: L.
So its not: ]pad[
The ear that looks like an L goes toward the top on the outside in the rear. I believe this ear also has the wear indicator on it. I could go look to make sure if you want me to.
Re-reading your post, are you sure those are front pads? I just installed blues on my 2004 (new body style) and the rears have the wear indicators. The fronts were all completely identical with no wear indicators.
So its not: ]pad[
