Load Range E??
I too run just under 50 PSI on my Pro Comp Extreme Muds w/ Load range E and its just fine. maybe just a little stiff. Might try 45 or so...
My load "D" tires seem good at 38-40, so 45-50 should be good for "E" tires, even loaded a bit. The tires will tell you what is good if not worn even, but starting at 45 should be a good average. Hell, semi-trucks run around 100 psi in their tires, so nowhere near 80 psi is needed, probably 50 max. The higher load range means basically your tire is more capable, not that it needs more air for everyday driving.
