Truck Pulling to the Left While Braking
Old Nov 21, 2007 | 02:14 PM
KillerUSMC's Avatar
I just had new brakes put on my 01 screw 4x4. I had to put new rotors up front too. Well now the truck is pulling to the left when I brake. I called the shop and the guy said that sometimes with heavy trucks like mine it takes a little bit for the brakes to "settle in". Should I just drive it for a few more days and see if it goes away? Thanks
Old Nov 21, 2007 | 03:32 PM
F151's Avatar
Give it a whirl and see how it goes.... I'm sure you'll be taking it back to them in a few days though. The pads will seat themselves after the first few stops.
Old Nov 21, 2007 | 11:54 PM
Jughed's Avatar
Ask the shop if they will put that in writing just incase you kill yourself or someone else on the road. I have never had brakes take more than backing out of my driveway to "settle in" If it is pulling to the left only while braking, 95% of the time means something is not working on the right side. If it is pulling all the time something aint right on the the left. Semper-Fi
Old Nov 22, 2007 | 09:41 PM
2006M50B's Avatar
X2-if it only pulls left while braking something on the right side isnt working or the left side is working to good-either way it isnt right and should be checked
Old Nov 23, 2007 | 05:38 PM
ramnj's Avatar
I haven't had that problem when replacing the brakes and turning the disks.
Old Nov 24, 2007 | 09:29 PM
torkum's Avatar
I had that problem once when I was working on a Ranger and it was because I didn't use the shims that came with the new pads. The pads that came off the truck had them so I put the shims on the new pads and the problem went away.
