do they fit?!?!?!?!
Old Nov 7, 2007 | 09:50 PM
tfast150's Avatar
do they fit?!?!?!?!
i have an 03 xtr torsion bars are tightened and i have bags on the back...with 1.5 inch wheel spacers will 35x12.5 R17 pro comp Xterrains fit in the wheel wells?....has any one tried to fit 35s with no body or suspension lift?
Old Nov 8, 2007 | 12:04 PM
wandell's Avatar
Not unless you remove the wheel spacers. You can fit the 35x12.50's (barely) by using your OEM wheels. You will have some minor rubbing on the frame at full steering lock however. I know the wheel spacers would push the tires outward and cure that but they would rub the wheelwells then.
