whats the difference and will they fit
Old Nov 7, 2007 | 01:32 PM
gators241987's Avatar
Alrite, last tire and wheel question I ever ask. I just ordered my pro comp stage 2 6 inch lift along with moto metal 951 20x9 6 on 135 bolt pattern with 35s. the 20x9 have 5.18 bs and an offset of 30mm. the call called me and told me they were on national backorder but they did have the 20x10. these have a bs of 4.79 and an offset of -18mm. what exactly is the difference between the two? which one will stick out further? will they both fit the tire without any rubbing issues? thanks
Old Nov 7, 2007 | 01:42 PM
mSaLL150's Avatar
the 20x10 will stick out about 1.5" more then the 20x9 since it has less backspacing. since you got the stage 2 kit with new coilovers, you shouldnt have any rubbing issues. if you do, it wont be anything that a little trimming cant fix. should look great
Old Nov 7, 2007 | 05:04 PM
so how far out from the stock wheel will they stick out? i have fender flares, so about how far out from them would they stick out?
Old Nov 7, 2007 | 09:10 PM
wandell's Avatar
A 10 inch wide wheel with 4.79 inches of bs will stick out about 3 1/4 inches farther than the OEM wheels. The 9 inch wide wheel with 5.1 inches of bs will stick out about 2 inches farther than the OEM wheel.
Old Nov 8, 2007 | 12:27 AM
Shrkbait's Avatar
Be careful on the 4wheelparts website, I have been shopping as well and found there are a number of 20x9 inch wide wheels listed with 30mm offset and 5.18 inches of backspacing, but this is not accurate, they actually have 6.18 inches of backspacing.
