Tire Question - With AS 2.5 Kit
Old Nov 5, 2007 | 01:11 PM
CopeSteelers's Avatar
All,
Any help is appreciated. I am on order the AS 2.5 Leveling kit for my 2006 Ford F-150 Crew Cab.
When installed I am getting rims and tires and came across a steal for some rims.
18X9 Gear Alloy Lockers
Bolt pattern 8X170MM (6.69in) with +10 offset
My question is will these rims first of all fit the truck and secondly what size tires will I need with these rims. I would like to get an agressive looking, low cost (of course) tire that is as large as possible without rubbing.
Any feedback is appreciated. If these rims would cause any issues I would can always go another route.
Thanks,
Cope
Old Nov 5, 2007 | 03:21 PM
hawg_man's Avatar
Those rims won't fit, however if you can find them in 6x135mm bolt pattern they would......if you can consider the pro comp xteme AT's, nitto terra grapplers, bfg at's etc. you are gonna find it hard to find a 18'' tire that is "low cost"....Do you have a 4x4 or 4x2? that will make a difference for your tire size.
Old Nov 5, 2007 | 08:04 PM
wandell's Avatar
I agree.
