33x12.50 on stock wheels
Old Nov 1, 2007 | 05:20 PM
redneckhunter24's Avatar
i have a 2001 supercrew 4x4, i've been searching the site and it looks like i can fit 33x12.50 tires on my stock wheels. any issues with the wheels only being 7.5 inches wide? i thought the minimum wheel width was 8in. for those tires. also should i expect these tires to rub at all? thanks
Old Nov 1, 2007 | 08:29 PM
wandell's Avatar
Most tire manufactures recommend an 8 to 10 inch wide wheel for 12.50 inch wide tires but you will be fine using the oem 17x7.5 inch wheels. Just don't run the air pressure to high, which combined with the narrow wheel will cause the center portion of the tread to wear slightly faster than normal.
