last rockstar q....
Old Oct 25, 2007 | 03:43 PM
K1NGoftheRanch's Avatar
last rockstar q....
okay so i was talking to 4wheelparts and the guy said if i go with the 20x8.5 with the 6.13" backspacing i wont be able to go with a lift like fabtech or anything. my question is since you can run stock rims on the rancho lift....would these work without rubbing on the spindles? i really dont want to go with to little a backspacing (the next one is 5.1" and i have to have them custom drilled for 6x135 from kmc) b/c i dont want them to stick out to far if i decide not to lift in the spring but i want the option. thanks
Old Oct 25, 2007 | 04:43 PM
Copenhagen848's Avatar
My rims are 18x8.5" and have 5.75" of backspacing and I have the Rancho lift. I just measured and the backside of the rim is about 1.25" away from the spindle however the fattest part of the tire sidewall (35x12.5" Toyo M/Ts) is only .75" inches away from the spindle. You'd be cutting it close, but it may work
