Brakes making a thumping sound.
Old Oct 12, 2007 | 05:27 PM
TX2K1's Avatar
I have a 2001 expedition (2wd) that makes a thumping noise when I use the brakes. It's coming from the passenger front wheel but only when slowing the truck. It doesn't happen when the truck is not moving and I press the break pedal. I'm thinking this is likely just the caliper going out, but I'm not sure.
Old Oct 12, 2007 | 07:56 PM
F151's Avatar
Just a noise? No vibration, shake, pulsating????? Does it stop good? When was the last brake inspection........
Old Oct 12, 2007 | 08:56 PM
hivoltagefx4's Avatar
Could be a warped rotor which is a very common problem.
Old Oct 13, 2007 | 08:11 AM
TX2K1's Avatar
[QUOTE=F151]Just a noise? No vibration, shake, pulsating????? Does it stop good? When was the last brake inspection.........
No vibration or shaking and it does stop the truck fine. I put pads on the front end about 6-7 months ago.
Old Oct 13, 2007 | 08:14 AM
TX2K1's Avatar
the truck does have 90k miles on it, so it's probably time to change the rotors.
Old Oct 21, 2007 | 09:23 PM
TRITON_2002's Avatar
Sounds dumb, but make sure your lugnuts are tight......
