Brake Dust Fix ???/
Old Oct 10, 2007 | 09:05 PM
lukep's Avatar
Brake Dust Fix ???/
97 F-150XLT....I get a tremendous amount of brake dust. New pads don't seem to help. Can you buy dust covers?
Old Oct 10, 2007 | 09:08 PM
BLUE20004X4's Avatar
You're new here, so I'll give you some good quick advice, Carquest "blue" semi-metallic pads and new or re-surfaced rotors. If it seems to brake fine, like pedal feel, get these pads or Wagner Thermo-quiets semi-metallics. Case closed.
Old Oct 10, 2007 | 10:36 PM
torkum's Avatar
Xs 2
Old Oct 11, 2007 | 06:55 AM
hivoltagefx4's Avatar
Can't go wrong with what Blue said! That's what I'm doing myself!!
Old Oct 11, 2007 | 07:11 AM
madcat6183's Avatar
Likewise, Im hopefully installing tonight. Just need to find a friend to help bleed the system.
Old Oct 11, 2007 | 05:56 PM
Buzzz's Avatar
Why do you have to bleed to put new pads on?
Old Oct 11, 2007 | 07:05 PM
Nope, only when changing the calipers or lines or things that will leak fluid out. Compressing the piston(s) in the caliper slowly prevents leaking out of the resevoir which alls ya gotta do is top up if it's low. The cap says what DOT number of fluid to add too, don't mix different ones.
