07 screw hope I didnt make a mistake
Old Oct 3, 2007 | 07:55 AM
T-Boune's Avatar
07 4x4 with leveling kit and aal. I ordered 35x12.5 18 tire with a 18 x10 wheel with 6'' backspace. I saw that another member had same size tire but 8.5 wheel and reported no rubbing at all. Going with a 10'' wheel will I get the rubbing. How much father will my 10'' wheel stick out with 6'' back space? Do you think I should (could)cancel my order and get a smaller wheel width? This site ROCKS!!!
Old Oct 3, 2007 | 01:03 PM
051fdrof's Avatar
Your new wheels will stick out 2" more than stock, but I would be more concerned about the backspacing. Factory is 5.5" so now you've pushed the back of the wheel in another 1/2 inch.
Old Oct 3, 2007 | 05:28 PM
hawg_man's Avatar
yeah those will probly rub pretty bad. To my knowledge you need a 8'' wide rim with around 6'' bs to fit 35's with no problems.
Old Oct 3, 2007 | 08:34 PM
wandell's Avatar
I agree. I think you are gonna have some serious rubbing problems. I'd keep the rims but go down to a 33x12.50-18 or 325/60-18 (33x13.00) tire.
Old Oct 4, 2007 | 08:10 AM
T-Boune's Avatar
I took your advise
I appreciate all the advise. I changed to a 8.5 rim with 5.75 back space. I hope that will be alright. I want to stick to the 35x12.5 tire because from looking at pics the 33'' tires look too small with the leveling kit. Thanks!!!
Old Oct 4, 2007 | 11:52 AM
hawg_man's Avatar
you are probably gonna have some issues, but good luck! if it fits okay then it will look sweet!
Old Oct 4, 2007 | 02:06 PM
The 8.5" wheel with the 5.75" BS will stick out 3/4" more than stock, the tires should clear the front lower wheelwell probably without any trimming.
Old Oct 4, 2007 | 02:35 PM
outlawz28's Avatar
Registered User
your step will work fine with a 35" tires and 8.5" rim. Might have to trim a little but nothing major and you will be happy going with 35" over 33" tires.
