2.5" leveling kit with 35" tires for 2004 F150
Old Sep 26, 2007 | 05:30 PM
GymJunkie0515's Avatar
So has anyone on here had a 2.5" leveling kit with 35" Toyo Open Country M/T tires on a 2004-2007 F150A guy at Les Scwab said its imposible to put a 2.5" for 35" tires and I've seen a lot of pictures of them so I know its not. So what would I have to do to make it fit?
Ask them to offset my tires or something. Im clueless if anyone can help me in what they did that would be great.
Pictures would be awesome if you have any.
Old Sep 26, 2007 | 06:07 PM
07screw's Avatar
I was told that the toyo m/t would not fit also because of the side lugs
so i went with a 35x12.50x18 procomp extreme a/t and it fit no problems
there is a member here that has that setup with minor rubbing at full turn only
look through the aftermarket wheels and tires treads theres one that was started by bluesteel 05
he has those tires in an 18" i think
anyway very minor rubbing
hope this helps
Old Sep 26, 2007 | 07:08 PM
LaVaDog's Avatar
I am in a '04 FX4 w/ a 2 1/2" AutoSpring leveling kit and am running 35x12.50x18's on the stock rims with Toyo M/T's.
Old Sep 26, 2007 | 08:07 PM
05extcabflare's Avatar
05f150 with 35x13.5x18 procomp extreme AT on maxx 6 rims Pictures in my gallery of modifications
Old Sep 26, 2007 | 08:31 PM
05'ThumpinSTX's Avatar
Same question
I had the same question. 2.5" Tuff Country Leveling kit- I decided it would be safer to stick with 33" Toyo MT's instead of the 35's. I dont need any rubbing problems especially because I pull a Trailer 75% of the time and I ride kinda rough. Besides the 33's look just as good! Ohh and as long as you have sick rims it totally makes up for the 2" of rubber! 20" KMC XD rockstars in black. I rest my case. haha
Old Sep 26, 2007 | 08:32 PM
Ask the guy if he would like to bet a set of tires, all you need is the right wheels and a leveled 4x4.
Old Sep 26, 2007 | 08:53 PM
Grubrunner's Avatar
On stock rims or aftermarket?
Here's mine on aftermarket -
Old Sep 26, 2007 | 10:27 PM
keith_bennett's Avatar
With oem, you will have minor rubbing at full steering lock. If you get aftermarket wheels with similar specs you will be fine.
Old Sep 26, 2007 | 10:34 PM
07screw's Avatar
i dont understand how you got that setup to fit with 20x10
they look like they have a + offset could they be a 9" wheel?
csabatka1's Avatar
35" x 12.5" x 20" Toyo's m/t's on MB Motoring Predators. No trimming or rubbing, 2 1/2" leveling kit.
Old Sep 26, 2007 | 11:04 PM
Prolly a good amount of cutting. With that setup i would want and aal too. Would help it not look soo stuffed.
Old Sep 26, 2007 | 11:12 PM
Clearance?
Would I have gotten the same amount of clearance with 35's as say a FX4 or 4x4 Lariat on my 2WD STX? I heard the 4x4's are taller stock than 2wd. Thats why I stuck with the 33's. I still think my 33's will look just as bad ***!
Old Sep 27, 2007 | 02:30 AM
Grubrunner's Avatar
No.
All the info you want is HERE
