New Tires- Local Guy
Old Sep 25, 2007 | 12:54 PM
walldo65's Avatar
Hey-
Quick question- Will it fit?
2007 FX4 SCrew, 2.5"AS & 1.5"AAL: Will the BF Goodrich AT 285/65/20 on my stock 20" fit on my truck? (Truck came w/ 275/55/20 Perellis) Will I have any rubbing issues? The new diameter will be 34.59" and the new width will be 11.22"
I need to know before because I'd be buying from the local 'Mom and Pop' tire place and he will need to order the tires - pretty much locking me into buying them...
Thanks!
Old Sep 25, 2007 | 02:11 PM
smitty'slariat's Avatar
I think you will be just fine. You here of people running 35x12.5 on there stock 20's with the leveling kit, so I think that a 34.5 x 11.22 should work just fine, and you should experience no rubbing. I would like to have others back me up, but I run 35's on my stock 18's with with the 2" AS and they do not rub during daily driving, only if I crank the wheel the whole way and hit a bump or something will they barely rub, so I know the stock 20 is a little wider, but and close to the same backspace so you should be just fine with the 285's with zero rubbing issues. Hope this helps.
Old Sep 25, 2007 | 05:21 PM
07screw's Avatar
x2!
Old Sep 25, 2007 | 05:46 PM
Russ47's Avatar
x3!
Old Sep 26, 2007 | 08:08 AM
walldo65's Avatar
Thats what i thought... Thanks guys! I'll order the tires today.
