Need help by sunday...
I need to know if the oem factory chrome wheel for a 2006 f150 has a +44 offset? it is a 18 inch by 7.5 with 6x135 bolt pattern. UPS damaged 1 of 4 wheels I bought from the classifieds and I found one on ebay but want to be sure it is the same because the guy has it label as f150 and expedition... thanks to all who reply.
the center off the wheel is 0 offset
so if the wheel is 7.5" wide
at 0 offset the backspacing would be 3.75"
so you then add the +44 offset to that would make it 5.48 backspacing
7.5 divided by 2= 3.75+44mm=5.48
that should be the same wheel
hope this helped
hope this helped
