04-07 lug pattern?
Old Sep 3, 2007 | 09:38 AM
wdhigh's Avatar
04-07 lug pattern?
Are all 04-07 rims the same lug pattern for 2wd and 4wd?
I have the chrome clad wheels and was looking on ebay and some descriptions say 2wd while some say fits both. Wanted to double check.
Old Sep 3, 2007 | 09:51 AM
wandell's Avatar
Yes, they all use the 6x135mm bolt pattern. THe only different wheel is on the trucks with the 7700lb. package. They use a weird 7 lug pattern.
Old Sep 3, 2007 | 09:56 AM
wdhigh's Avatar
thanks for the quick response.
Old Jan 27, 2015 | 10:37 AM
nicks07f150's Avatar
Lug Pattern
So is 6×135mm the same as 6×5.5? I'm not sure what the conversion Is.
Old Jan 27, 2015 | 11:37 AM
No, they are not the same.
Old May 28, 2021 | 09:21 PM
Csuttles604's Avatar
04 f150 4x4 front bearings and or hub assembly
front drivers wheel feels like its falling off. Jacked it up and wheel wobbles everywhere inside the hub housing. Tried to get front hub assembly from local advance because I need it to soon to order it off line but they said u couldn't get the whole assembly just the bearing. Im stumped n goggles not helping. Have u dealt with this and do you know what I need to tell these cats to get the right part or parts? Thank you
