22's
Old Aug 24, 2007 | 01:49 PM
Wildebird's Avatar
22's
Found a good deal on a set 22" wheels with 305/45/22's off an Expedition. Will these tires/wheels work on my '03 F-150 Supercrew? How much will I be able to lower it with the combo?
Thanks, Clint
Old Aug 24, 2007 | 01:51 PM
305/45/22 is gonna be a tall tire, you might have a little rubbing, and you wont be able to go lower then 2/4 for sure, maybe not even 2/4
Old Aug 24, 2007 | 01:58 PM
BullRing's Avatar
Go to the tire Company website and see the actual size of the tire. So you can decide if it will work.
Old Aug 24, 2007 | 02:00 PM
Wildebird's Avatar
Well I was actually wrong on the tire size. Its a 305/40/22. Still have a rubbing problem?
Old Aug 24, 2007 | 02:04 PM
Wildebird's Avatar
They are Khumo's and their website doesn't give a diameter, just the width. They say 10-12.
Old Aug 24, 2007 | 02:09 PM
305 is about 10.5" wide, and yes you will have rubbing issues at full steering lock. I have rubbing issues with my stock tires lowered 3/5 Stock rims are 7 or 7.5" wide for comparison
Old Aug 24, 2007 | 02:22 PM
hawg_man's Avatar
actually about 12-12.5'' wide. 305/45/22 is the size Wandell has on his expy and they fit great. I assume the expy they came off and your truck are both in the 97-03 range. otherwise they wouldn't fit. I don't know anything about lowering so I won't go there.
Old Aug 24, 2007 | 02:25 PM
Wildebird's Avatar
Yea, they are coming off like year Expy.
Old Aug 24, 2007 | 02:26 PM
hawg_man's Avatar
whats the width and bs of the rims?
Old Aug 24, 2007 | 02:27 PM
315s fit on an 11" rim with a little buldge making it a 12" wide tire
305s would be narrower then that
Old Aug 24, 2007 | 02:31 PM
hawg_man's Avatar
305 millimeter = 12.007 874 016 inch
315 millimeter = 12.401 574 803 inch
Old Aug 24, 2007 | 02:32 PM
yes but the measurement is of the section width of the tire (the widest part of the sidewalls), not the actual tread width, so we are kinda agreeing to disagree right?
Old Aug 24, 2007 | 02:36 PM
hawg_man's Avatar
SECTION WIDTH
Definition: The distance between a tire's sidewalls measured at the widest part of the tire.
I guess. I am not trying to get into it with you, I was just stating what I always understood to be right.
Old Aug 24, 2007 | 02:42 PM
SECTION WIDTH
yah if the sidewall look like this ( ) then the widest part isnt really the tread width. Its weird arguing about a .5" difference
Old Aug 24, 2007 | 03:05 PM
BullRing's Avatar
Its happens
