tire psi and mpg
tire psi and mpg
hi i have bfg at tires. they are 275/70/16. what tire pressure will give my the best mpg with out hurting my tires as far as tread ware and rick of a blowout? i have a 2001 f150 extcab 4x4
If I read the chart right at BFG's site, those are a load range D tire with a max PSI of 65. I would run them at 45 on an F150. Higher and you will probablt get too much wear in the center tread. Lower and you will get lower milage and too low a much better chance of a blowout.
Originally Posted by chrism9232
should i put more in the front because weight on them?
