Tire rotation
Old Aug 5, 2007 | 05:03 AM
JohnG6's Avatar
Tire rotation
For several years I've driven front wheel drive cars. I always used a "modified X pattern" when rotating the tires (back tires straight to the front, front tires crossed to the rear). This keeps the tires rotating in both directions and I've had good luck with it.
Is anything different on a rear wheel drive truck? Should I modify my pattern? I have stock Michelin tires that aren't directional.
Old Aug 5, 2007 | 06:55 AM
kingfish51's Avatar
You can do it the same. The tires are not uni-directional, so you can use the X pattern.
Old Aug 5, 2007 | 09:44 AM
wandell's Avatar
I agree.
Old Aug 5, 2007 | 10:20 AM
either X or just straight back and forward will work, assuming you dont have dirrectional tires
