Wandell question
Old Aug 1, 2007 | 11:41 AM
Swift's Avatar
Wandell question
I like your Supercrew! I have a 2003 F150 Supercrew 4X4 and will level with the torsion bars. I want to put 295/70/17 Terra Grapplers on it and want to be sure they won't rub if I drive through a ditch. I also drive a lot of gravel roads. Will they stick out past the fenders and throw rocks and mud down the side of the truck? Thanks
Old Aug 1, 2007 | 12:04 PM
Swift's Avatar
One other question. Can the speedometer be recalibrated through the computer on the 2003's or does it require changing the gear in the speedometer?
Old Aug 1, 2007 | 12:17 PM
keith_bennett's Avatar
The 295's will fit.
Old Aug 1, 2007 | 03:48 PM
hawg_man's Avatar
yeah they'll fit, they will only stick out about 3/4'' farther than a stock 265.
295 is 12'' wide and 265 is 10.5'' wide.
Old Aug 1, 2007 | 06:02 PM
cpaggie_07's Avatar
Your speedo will only be off about 3 MPH at around 70 MPH. The factory speedo is only accurate to within +3 or -3 MPH anyway, so I would't worry about it. But if you ever get an aftermarket chip or programmer, you'll be able to fix it.
Old Aug 1, 2007 | 11:42 PM
wandell's Avatar
Right, and your dealer can also recalibrate the computer to correct the speedometer.
Old Aug 2, 2007 | 05:20 AM
Swift's Avatar
Thanks. My chief concern was the tires sticking out past the fender enough that debris will get thrown into the side of my truck.
Old Aug 2, 2007 | 09:22 AM
wandell's Avatar
That will depend a lot on your wheel. They won't stick out using the oem wheels.
