bridgestone dueler at revos
anybody know if the bridgestone dueler at revos are a decent tire?i am going to crank my torsion bars up so i can level my truck and run a 285/70/17 which is a 33.
I have this same size Revo on my 2003 Screw and they are awesome. I needed to trim the edge of the plastic on the driver's side bumper end as it rubbed at full lock. Cranking the torsion bars would have been the better solution.
I've been running them for about 5,000 miles and I love them. The ride is much better than the factory Generals, and if there is a little more noise, it's barely noticable. They're great on everything, including snow. I would definitely buy them again.
hey kirk333 you have the 285s? what with rim did you run?
I am running a P series. I do an awful lot of highway traveling and comfort was more important than off roading in this case. There are times where I wish I would have bought the LT but not often. The P series are obviously lighter and balance better. The four ply sidewall is a much better ride. However if you plan on doing a lot of backroad travel or off roading, the LT will hold up a lot better.
