wheel offset?
Old Jul 20, 2007 | 12:06 AM
Shootermay's Avatar
wheel offset?
is wheel offset o when rim is in the center of wheel and - when the center of the wheel is in so that the tire sticks farther out? i am putting a 6 inch lift on my 150 and am going with bfg mud km 315/75 r 16 on a procomp series 97 rim and i want the tire to stick out from the truck(the side) i like the look but dont know how to do it without spacers thanks
Old Jul 20, 2007 | 12:15 PM
wandell's Avatar
The 97-03's came with 16x7 or 17x7.5 inch wheels. The backspacing on both is 4.5 inches. If you go to a 16x10 inch wheel with 4.5 inches of backspacing, it will stick out 3 inches farther than the OEM 16's and 2.5 inches farther than the OEM 17's. To get an idea how it looks, take a look at my gallary.
Old Jul 20, 2007 | 01:10 PM
Shootermay's Avatar
wandell thanks for all your help i don't have the kind of money for a costly mistake but i think i have it all figured out now. skyjacker 6" 315x75r16 bfg muds on procomp series 97 wheels 16x10 4.5" backspacing with 5.10 gears? Well wandell do you think that will fit all right?
Old Jul 20, 2007 | 01:15 PM
DieselWeb's Avatar
Link for wheel offset and measurements:
https://www.rsracing.com/tech-wheel.html
Old Jul 20, 2007 | 01:28 PM
chug4real's Avatar
Hey man if your only planning to run 35's then stick to 4.10 gears or maybe 4.56's
Old Jul 20, 2007 | 06:41 PM
Shootermay's Avatar
i punched in the wrong number i meant 4.10s what is going to be the difference in mpg between 4.10 and 4.56 thanks
Old Jul 20, 2007 | 10:36 PM
wandell's Avatar
That combo should look perfect. I'd go with 4.56 gears personally (especially if you don't have the 5.4 or you tow a lot).
Old Jul 20, 2007 | 11:07 PM
Shootermay's Avatar
i keep running into more problems. the only rims i can get so far that ive found are 16x8. will this cause problems/ look bad on a 35 12.5 tire?
Old Jul 21, 2007 | 10:38 AM
wandell's Avatar
I think 10's would look a lot better personally. There are hundreds of 16x10's available.
