the front disk is lose it is rigth?
Old Jul 9, 2007 | 09:01 PM
luna873's Avatar
Unhappy the front disk is lose it is rigth?
Hi I just change the pads for mi f150m 1997 4x4 but im worry because never see on another cars the disck lose after I toke the caliper it is ok or they should be tide with something thankm you!
Old Jul 9, 2007 | 10:27 PM
Rikster's Avatar
The rotor just slides on and off, so it sounds like you are fine, but PLEASE proof read your posts before submitting.
Old Jul 9, 2007 | 11:19 PM
twintips_17's Avatar
Your rotors will just slide off. The lug nuts hold them on along with the rim. Proof Read Please.
Old Jul 10, 2007 | 07:21 AM
torkum's Avatar
Is that Pig Latin?
Old Jul 10, 2007 | 07:27 AM
keith97xlt's Avatar
disc loose?? the wheel holds the disc tight. when you put wheel back on the rotor will be fine.
Old Jul 10, 2007 | 08:47 AM
BLUE20004X4's Avatar
Kind of a pain, huh when they're loose like that. When re-installing, I always put at least 2 nuts back on all the way tight to keep things centered until the end. I also put alot of antisieze in places so it keeps the rotor away.
