to stagger or not to?
Old Jul 9, 2007 | 12:01 PM
-VadeR-'s Avatar
I soon will be getting some 22" wheels but Im wondering if I should stagger the tires. Would I be able to get the offset adjusted through the dealership? It's a 2007 F150 Screw. Anyone here stagger? If so, what size and what do you recommend for 22" wheels? Thanks
Old Jul 9, 2007 | 12:32 PM
wandell's Avatar
Are you talking about staggering tire size or wheel size? I would not do either. The only trucks I've seen with staggered sizes were laying frame on airbag suspensions and they only did it because they had to have a smaller front size, not because they wanted to.
Old Jul 11, 2007 | 05:07 PM
croatone's Avatar
staggered wheel width looks great on a dropped truck. I wouldnt unless your truck was pretty low to the ground. You can not adjust offsets of wheels. You have to order them that way, You cant adjust a solid piece of aluminum. You also with staggered wheels wouldnt be able to rotate them because it would look terrible. Like the fat rears on the front with the narrower wheels off the front on the back. Therfore wearing tires out a little sooner as well.
