305/75/16 on stock wheels
is any one running 305/75/16,s on there stock 2001 wheels if so could you post some pics i have heard they will wear faster is this true and if i turn up the t-bars will they clear mine is a step side so it has the stupid mudflaps
will that make any diffrence thanks in advance
some guys are running them on stock wheels, I ran them on my old F-250 with stock wheels (also 7" wide) and I highly DO NOT recomend it, they will look, wear and handle funny. get some wider wheels or go with a 285/75R16 tire, it's the same height but not as wide and will fit on your stock rima lot better.
i also think they will be too wide i have the 285s and theyre fine, i have a stepside too with the mudflaps and even with the 285 they hit the mudflaps, i dont find it to be a big problem, would probly be easy enough to trim them of just take them off
get a body lift and some 10" wheels and it will look like a totally differnt truck. don't forget the gap guards with the body lift...
or you might be able to fit those 305's on 8" wheels with just cranking the torsion bars a bit, but the body lift and 10" wheels will look a lot better
body lfit & 10,s
i really want to put some 10,s and a body lift but i just traded my z71 in on this truck and it had the same set up mentioned above and it rode really bad i don,t know if it was the lift or just the chevy any thought,s
